911 2.7 charging problem
can anyone help?
my car starts fine, battery light goes out, about 20 mins later the battery light stays on until about 2200rpm at no stage does the alternator light come on or even flicker, i had the alternator reconditioned and the engineer said it was charging well on his bench, i checked with a meter it is only reading 11.8v at tick over increasing to 12.9v at 3000rpm.
Old 03-13-2010, 06:51 AM
Your voltages look too small. You should be getting more voltage out of the alternator. You could have a couple of diodes going bad.
What year is your car? Do you still have the external voltage regulator?
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 03-13-2010, 07:00 AM
its a 1975 with a external regulator and had one diode replaced when sent for repair
Old 03-13-2010, 07:14 AM
general rule of thumb
always replace external regulator when rebuilding alternator
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-13-2010, 07:45 AM
ttt
Old 03-13-2010, 11:18 PM
ttt
Old 03-14-2010, 10:20 AM
Senior Advisor
James Brown's Avatar
Yup, there is your problem (most likley). The regulator does just that, regulates voltage. Try that and see what it does.
08 Cayenne Turbo
Old 03-14-2010, 10:31 AM
i will give that a try
Old 03-14-2010, 11:57 AM
