tshore's Avatar
Will 964 dash fit an 86 Carrera
Looking at a replacement dash. Will one from a 964 work for an 86 Carrera?
Thanks!
T
Tim
'86 Targa Iris Blue
'96 Audi A4
Old 03-13-2010, 06:08 PM
Bill Verburg's Avatar
no,
911 from '87 up and 964 and 993 are interchangeable though
Bill Verburg
Old 03-13-2010, 06:30 PM
tshore's Avatar
Thanks...do you know what the difference is between '86 and '87? '86 has the big center vent, and looks identical to '87. Does it attach differently?
Tim
'86 Targa Iris Blue
'96 Audi A4
Old 03-13-2010, 07:18 PM
Hi I thought it is 85 down wont fit and 86 and up will fit .Thats what I. have been told. Karl
Old 03-14-2010, 05:41 AM
Pre Registered
tchanson's Avatar
Originally Posted by Bill Verburg View Post
no,
That's not correct. Dashes from '86 to '98 are the same, with some minor changes to the end caps and the upper defroster cover on the 964/993's.
A 964 dash will fit an '86 Carrera, as its essentially the same piece.
Tim
Old 03-14-2010, 09:51 AM
Tim
I guess Ill need to go back a double check, they changed the dash in either 86 or 87 for sure
I've been scrounging parts for my 993 and was pretty sure that I needed '87 up but it could easily be '86 up
Bill Verburg
Old 03-14-2010, 09:59 AM
Kevin Stewart's Avatar
Hi yes the dash will work, the problem is the ac vent is different and the defrost vent is different, the defrost doest line up perfect but works as well as a 911 does not worth a crap, it seem the ac vent takes a little work my total instal was 2 hours, i did use self taping screws on the defrost, so make sure you get all the vents or you will have to source the, Kevin
Old 03-14-2010, 10:13 AM
Pre Registered
tchanson's Avatar
It's '86 forward.
Tim
