-   -   SC Flasher Relay (http://forums.pelicanparts.com/porsche-911-technical-forum/531171-sc-flasher-relay.html)
gredtarga 03-14-2010 04:43 PM
SC Flasher Relay
Found it, and I have all the symptoms; erratic, wrong or no direction for the turn signals, and intermittent function for the flashers. I bought a Hella, got a good grip on the bad relay but it won't come out with what should be enough force. I don't want to break anything. Should I be worried? Any ideas?
http://forums.pelicanparts.com/uploa...1268609836.jpg
86 911 Targa 03-14-2010 05:22 PM
"Too much force".
I don't know what to much force might be.
I would hold down the relay connecting interface platform (base), and very gently wiggle the relay back and forth.
If the relay is on a harness, you should be able to wiggle both sides.
Take it slow.
Gerry
gredtarga 03-14-2010 05:46 PM
Thanks Gerry. I can only get one hand in. I'll have to try and get someone to maybe hold down the base from the trunk access with something.
I had a brake light switch connector melt and I'm having flash-backs when it wouldn't come off. I had to dig out the broken spade out of the connector; Not fun.
I'll keep trying.
cantdrv55 03-14-2010 11:37 PM
I got at mine from the hood of the car.
86 911 Targa 03-15-2010 04:45 AM
+1
mike monde 03-15-2010 09:16 AM
I was able to pull mine from the front going in through the back of the dash. I am pretty sure I was able to see it from there and reach in and get it out. There was just enough slack in the wire. I believe it was behind the brake fluid reservoir.
Hope that helps.
86 911 Targa 03-15-2010 09:32 AM
+1
