Unhappy SC Flasher Relay
Found it, and I have all the symptoms; erratic, wrong or no direction for the turn signals, and intermittent function for the flashers. I bought a Hella, got a good grip on the bad relay but it won't come out with what should be enough force. I don't want to break anything. Should I be worried? Any ideas?
Old 03-14-2010, 04:43 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
"Too much force".
I don't know what to much force might be.
I would hold down the relay connecting interface platform (base), and very gently wiggle the relay back and forth.
If the relay is on a harness, you should be able to wiggle both sides.
Take it slow.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-14-2010, 05:22 PM
Thanks Gerry. I can only get one hand in. I'll have to try and get someone to maybe hold down the base from the trunk access with something.
I had a brake light switch connector melt and I'm having flash-backs when it wouldn't come off. I had to dig out the broken spade out of the connector; Not fun.
I'll keep trying.
Old 03-14-2010, 05:46 PM
cantdrv55's Avatar
I got at mine from the hood of the car.
Old 03-14-2010, 11:37 PM
+1
1986 911 Targa.
Only in L.A.:
Old 03-15-2010, 04:45 AM
East Coast R Gruppe
mike monde's Avatar
I was able to pull mine from the front going in through the back of the dash. I am pretty sure I was able to see it from there and reach in and get it out. There was just enough slack in the wire. I believe it was behind the brake fluid reservoir.
Hope that helps.
OGRP3
RGRPNE
Old 03-15-2010, 09:16 AM
+1
1986 911 Targa.
Only in L.A.:
Old 03-15-2010, 09:32 AM
