I'm here to cause trouble
Torsion bar cap seal and ball joint wedge bolt
Does anyone know where to get those fabric-like washers used as a front torsion bar cap seal? (sits between the cap and cross member).
Also, does anyone know why the Bentley Book recommends replacing the ball joint wedge bolt? Can't find those either.... JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
sudo apt-get purge 930
901-341-475-00-OEM Porsche 911 & Carrera Suspension - Page 14 Ball joint wedge pin: 911-341-119-06-M260 Porsche 911 & Carrera Suspension - Page 13
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Thanks! Having the part numbers makes it simple...
Interesting that a search for "torsion bar seal" doesn't bring that right up... And the wedge bolt is a "threaded pin!" I'm still not sure why the "threaded pin" should be replaced unless it's obviously worn. JB
Senior Advisor
Lots of stress on the wedge pin, if your removing it it's a good idea to replace it, it's cheap but if it fails....
08 Cayenne Turbo |
...no need to complete THAT sentence! It wouldn't be pretty.... cheap insurance indeed....
JB
i know it's wrong forum, sorry, but jb, i have the pin which i ended up not using last year during my rebuild. PM me...
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
I bought new ones because I saw so many posts about people breaking them when installing them. I wanted to have some on hand just in case. Tapping them into place, as opposed to trying to pull them into place by tightening the nut seems to be the better way to install them. I saw it here on PP and it worked for me. You might be just fine reusing the old ones if you install them this way.
