robotman's Avatar
OEL gauge
My gauge reads in the red even when engine is warm, i checked engine oil level and it is about 3/4 the way up the stick. If i disconnect a wire at the oil storage tank under fender the gauge goes all the way up. Connect it again back to in the red.
What is the problem here?
Old 03-21-2010, 02:08 PM
Senior Advisor
James Brown's Avatar
Several things: bad sender, bad ground (corrosion). Check out some other posts on here about the same thing
08 Cayenne Turbo
Old 03-21-2010, 02:15 PM
