fzr1k's Avatar
Thumbs up thanx for your help
i have posted many threads about 82 sc and a hesitation/backfire problem i have check many things found many problems and fixed them but they did not effect the problem i was having. someone asked me what my timing advance was running and that put me on the right path. when i unhooked my vac advance no backfire. well as it turns out when i installed an msd in my car of coarse they dont have a diagram for porsche cdi distributors so i did what to the best of my ability( 20 years as an auto mechanic)i hought was correct. turns out after many tries all that was wrong was the 2 pickup coil wires were reversed. after tearing down the distributor and finding nothing wrong i sat and turned the dist and thought about things. my rotor was showing signs of firing off of the extreme corner . all of the sudden it hit me like a ton of bricks i reversed the wires in my cdi plug( when i installed the msd i cut no wires) whamo it runs like a clock so if any one ever runs into this problem after an aftemarket ignition install try the wire switch first. again thank you all so much i now love my 911 more than anyone could.
Old 03-23-2010, 05:29 PM
dshepp806's Avatar
like it when it ends well.....
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-23-2010, 06:49 PM
