-   -   clutch job comming up- anything else while engine is out? (http://forums.pelicanparts.com/porsche-911-technical-forum/53301-clutch-job-comming-up-anything-else-while-engine-out.html)
lagoon 11-30-2001 05:29 PM
engine & tranny is comming out soon. aside from oil pressure switch, thermostat o-ring, oil cooler seals, is there ANYTHING else to address to avoid future oil leaks? 81'SC
82SC 11-30-2001 05:42 PM
change o-rings on engine oil cooler
change gaskets for the oil thermostat and crankcase breather tube
change ALL clutch related parts...DO NOT SKIMP...
do a valve adjustment
MJ
check tech articles of the oil leak fixes...you can email me if you have any question on my article
Jim Smolka 11-30-2001 05:47 PM
Good time for a tranny gear oil change also. Much easier to fill the gear box when it is not in the car.
Also check that the Cam boxes are not leaking and that the oil return tubes are OK.
If you are removing the Flywheel, be sure to order new bolts.
