Sugar Scoops Rule :)
dave 911's Avatar
Sagging Targa headliner fix?
Hi -
The headliner on my targa top is starting to sag in 2 of the corners:
Is there a way to fix this myself?
Thx
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 03-31-2010, 04:53 PM
j_mancini's Avatar
Its glued on so just use spray on auto trim adhesive.
John
1982 911SC Targa ~ Gulf Blue (gone but not forgotten)
Old 03-31-2010, 06:29 PM
dave 911's Avatar
Thanks - so I guess you need to take the inside rails off to get to the underside of the headliner? I've never taken the top apart before - is it straightforward or are there any tricks to it?
Dave
'76 911S Targa
Old 04-01-2010, 04:21 AM
Ray_G's Avatar
Your headliner is sagging all over. They are just spray glued on. The sides are tucked under the frame, the front and aft edges are under the clips that the fwd and aft bars snap into. You don't have to take the frame apart. I would use headliner glue.
76 911S Targa
An ex F1 driver, and Porsche fanatic (my stepfather) once told me that if you listen very carefully on a quiet night you can actually HEAR Porsches rusting in the garage!
Old 04-01-2010, 04:43 AM
Bill Verburg's Avatar
I did mine a few years ago, it's very straight forward just a lot of little screws to keep track of. The foam tends to deteriorate w/ age, might as well buy a new one. The central area is glued on, I used 3M Headliner glue in a small spray can.
Bill Verburg
Old 04-01-2010, 05:06 AM
