| gregwils |
03-27-2010 12:40 PM |
Distributor Install Alignment
I am nearing the end of my rebuild and finally installed the distributor today. I have a question about the alignment or orientation of the distributor.
The engine is at #1 TDC. The pulley is directly over Z1 and the valve covers are off, so it easy to confirm I am definitely #1 TDC, not #4. When I install the distributor with the rotor over #1 TDC mark, the closest I can get is a few degrees before the TDC mark. See the picture. Thanks.
Wayne's book says the rotor needs to be "directly" over the TDC mark, but Bentley says "Note: The marks line up approximately, not precisely." Wayne is working on an SC in his book, but he doesn't call out anything different for a Motronic in the text.
Does the Motronic system adjust for this? I searched the forum and could only find a few loose references where it stated that a Motronic doesn't need to be exact. Can anyone give me a definitive answer? Thanks. http://forums.pelicanparts.com/uploa...1269718768.jpg
