-   -   83 sc help!!!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/533501-83-sc-help.html)
89-944NA 03-27-2010 04:20 PM
83 sc help!!!!!
Before you say anything, yeah, I'm a 944 (well actually 951) guy. I now have a 1983 SC, and a problem.
It idles at 1900rpm:eek:, and I really would like to lower that....How do I do that?:confused:
Help me please?????!!!!!
LWJ 03-27-2010 04:46 PM
Check for vacuum leaks.
mca 03-27-2010 04:51 PM
Need more details. Does it always idle high? If not, describe the situation.
I'd think vacuum leaks would make it idle lower (ie. taking off oil cap.)
Could be decel valve too. Easy to test and fix if it is.
89-944NA 03-28-2010 01:08 PM
It lopes when it is first started, then settles into a nice idle....once it heats up, the idle heads for the moon.
mca 03-28-2010 01:53 PM
I'd try plugging the decel valve vacuum line. Pull the line off of the decel valve nipple - right side of engine towards fire wall. Then plug the line with a golf tee. Report back.
T77911S 03-28-2010 02:46 PM
i take it by lopes you mean a low idle and barley turning over.
you may have more than one problem. i would look intot he following.
aux air regulator (AAR). check for 12v at the connector or stuck open.
WUR- check warm and cold control pressures, (WCP/CCP).
decel valve.
928jayson 03-28-2010 03:28 PM
sounds like your warm up regulator is backwards!
tcar 03-28-2010 03:47 PM
By "lopes" I'm guessing that the idle speeds up, slows down, speeds up, slows, etc.
Yes?
86 911 Targa 03-28-2010 03:54 PM
Give us more info.
When did this start?
Any recent service on the car?
Did you try removing the oil filler cap as per mca.
Good luck,
Gerry
DaddyGlenn 03-28-2010 04:03 PM
Sorry but it has to be said...... have you tried the "search" function? Tons of posts here on this and related subjects.
