89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
83 sc help!!!!!
Before you say anything, yeah, I'm a 944 (well actually 951) guy. I now have a 1983 SC, and a problem.
It idles at 1900rpm, and I really would like to lower that....How do I do that?
Help me please?????!!!!!
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 03-27-2010, 04:20 PM
LWJ LWJ is online now
Check for vacuum leaks.
Old 03-27-2010, 04:46 PM
mca mca is offline
mca's Avatar
Need more details. Does it always idle high? If not, describe the situation.
I'd think vacuum leaks would make it idle lower (ie. taking off oil cap.)
Could be decel valve too. Easy to test and fix if it is.
Old 03-27-2010, 04:51 PM
89-944NA's Avatar
It lopes when it is first started, then settles into a nice idle....once it heats up, the idle heads for the moon.
Semper Fi
Old 03-28-2010, 01:08 PM
mca mca is offline
mca's Avatar
I'd try plugging the decel valve vacuum line. Pull the line off of the decel valve nipple - right side of engine towards fire wall. Then plug the line with a golf tee. Report back.
Old 03-28-2010, 01:53 PM
T77911S's Avatar
i take it by lopes you mean a low idle and barley turning over.
you may have more than one problem. i would look intot he following.
aux air regulator (AAR). check for 12v at the connector or stuck open.
WUR- check warm and cold control pressures, (WCP/CCP).
decel valve.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-28-2010, 02:46 PM
sounds like your warm up regulator is backwards!
Old 03-28-2010, 03:28 PM
By "lopes" I'm guessing that the idle speeds up, slows down, speeds up, slows, etc.
Yes?
Old 03-28-2010, 03:47 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Give us more info.
When did this start?
Any recent service on the car?
Did you try removing the oil filler cap as per mca.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-28-2010, 03:54 PM
Tired Member
DaddyGlenn's Avatar
Sorry but it has to be said...... have you tried the "search" function? Tons of posts here on this and related subjects.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 03-28-2010, 04:03 PM
