1974 911 w/ 83 SC engine
Worth going up a sway bar size or two?
This is my stock rear sway bar on my 74, which I am guessing is a 16mm. How much bigger would I have to go up in size to have a noticeable difference in performance during hard street driving? How big of sway bars can a 74 chassis handle without having to weld on new brackets, modifications, etc.? I have to change out all the bushings anyway, so I figured if ever I was going to put better sway bars on, now is the time.
Old 04-02-2010, 03:10 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
I have a 75, and my mechanic just put on charlie bars. they are 25mm I believe. huge difference from stock. needed new brackets to hold them. probably more than you're looking for.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 04-02-2010, 03:15 PM
Where did you get the "charlie bars"? I just searched Pelican and couldn't find anything by that name. *Huge difference* is exactly what I want. The one thing I didn't want to do was swap them out for another size or brand that made absolutely no difference in performance. After doing some research I've realized that going up any marked size in sway bars is going to require new brackets, so if that's the case, then that's what I will do.
Old 04-02-2010, 04:02 PM
HWM,
JMHO, but even a Carrera swaybar upgrade is going to require rear mount replacements (Wevo) so that should be a given if you wish to make any changes.
Charlie bars are long NLA (unless you find a used set) and I'd recommend upgrading to a through-the-body-design such as Smart Racing's and others to get not only adjustability, but the ability to remove pre-load which can alter the car's handling in left & right hand corners.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-02-2010, 04:35 PM
just me
paulgtr's Avatar
My mechanic had a very good used set of charlie bars. but the smart racing bars are if not copies very similar. listen to what Steve says, it is exactly what my mechanic said
Old 04-03-2010, 03:45 AM
moneymanager's Avatar
Force required to twist the bar is a four power thing, so increasing the size of the bar by 10% adds 46% to stiffness, everything else being equal. You can feel 46% but it isn't dramatic.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 04-03-2010, 07:09 AM
