draab29's Avatar
Will 8s Fit?
Will Fuchs 8x16 et 10.6 fit on the front of a m491? Did a search but only found one person who tried it in 2003. Thanks
Dave
1984 911 M491
1986 911 Hotrod
Old 03-28-2010, 04:53 AM
draab29's Avatar
I would like to put the 8x16 et 10.6 on the front, running 225/50/16 and putting 9x16 et 15 on the rear with 255/50/16 tires.
I need a temporary wheel tire combo to run on an IROC backdate that has the right look until I can have Lindseys or Zuffenhaus 17s made. I have the wheels but don't have the rubber yet or I would just put them on and see if they fit. Thanks
Dave
1984 911 M491
1986 911 Hotrod
Old 03-28-2010, 03:45 PM
Wheels test fit......
Dave,
What's M491? Turbo look body? I have an extra set of 8" and 9" fuchs wheels with tires. You could try them on and see how they fit on your car. PM me.
Tony
Old 03-28-2010, 07:35 PM
M491 Coupe Owner
dsmeyer's Avatar
I have 8x16 Fuchs with the offset from an '86 944 Turbo, not sure if that's 10.6.
Tires are 225/50-16 and the car has been lowered. I had to roll the fender lips to stop some minor rubbing.
'Standard' 8x16 Fuchs offset will stick out about a 1/2" more than '86 944 Turbo 8x16 Fuchs.
Silver '86 Turbo Look Coupe
Old 04-03-2010, 07:21 AM
