-   -   Another alignment question (http://forums.pelicanparts.com/porsche-911-technical-forum/533598-another-alignment-question.html)
ossiblue 03-28-2010 08:11 AM
Need some insight on this, please.
While working under the front end of my 73.5 T trying to find a cure for a slight pull to the left, I noticed that the left tie rod was adjusted all the way "in" and the right tie rod adjusted quite a distance "out" as evidenced by the number of threads showing. I checked the steering wheel, and it is aligned correctly with the mark on the shaft and is straight when driving. I assumed that if all was correct, the tie rods would be adjusted the same approximate length.
The car, as far as I know, has never had front damage and shows no evidence of it. Can someone offer an explanation for this? Am I correct on my assumption of relatively equal tie rods? Will other adjustments to the suspension--camber, for example--account for this?:confused:
pete3799 03-28-2010 08:20 AM
Count the number of turns lock to lock then turn back 1/2 way.
Is the steering wheel still straight?
I'm guessing the rod ends were adjusted to straighten the st. wheel.
ossiblue 03-28-2010 08:24 AM
Yep, did just that early on and the wheel is straight. It just doesn't seem right that there is no more adjustment possible in the left tie rod--that's my concern.
Dixie 03-28-2010 08:34 AM
There are a few things that can cause the tie rod lengths to vary on each side. (Cross-camber, as you surmised, being one variable.) But your car sounds like the difference is extreme. If it was me, I'd have a shop check the alignment. Once you have all the readings you can decide if it's possible something is tweaked.
