CHT and crank sensor readings?
So I tried to fire up my 993 motor in a 78SC today.
I have got it cranking, oil pressure, sounds good, fuel in the rails, one king lead delivered a healthy spark, but not firing.
I pulled number 4 top plug after quite a lot of cranking and it was bone dry and no smell of gas.
I dont have a 993 manual, what ohm reading should I get across the CHT and crank sensors? (I have a DVM but no scope).
Running a 95 993 motor in an SC....
Old 09-09-2010, 01:10 PM
And if anyone has got the 993 part numbers for the CHT and crank ref that would be handy too.
Edit - So I think I found the part numbers, CHT is 993-606-013-00 and 996-606-105-00 for the crank.
Still need to know the ohm numbers.
Old 09-09-2010, 02:15 PM
maybe this will help?
Glen Pettigrew
Old 09-09-2010, 09:48 PM
Excellent, that's very helpful.
Many thanks.
Old 09-09-2010, 11:58 PM
So I just tested the CHT sensor with a meter, its 20 degrees C here today and I got a reading of 2.45Kohms.
Pretty much in the right place.
I've ordered a Crank sensor as the body of mine has sustained a bash and its a trickier thing to check, I havent used a scope for 15 years so i thought buying a new sensor easier!
Old 09-12-2010, 09:05 AM
