not_sure's Avatar
Lowered car
How low is you car, ground to fender lip. Looking more for pre 74 but all are welcome.
Tom
Tom
71T
http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=173
Old 12-02-2001, 12:55 PM
CamB's Avatar
Low. Can't remember what - about 24-24.5" with 195/60R15 (slightly small - should be 195/65).
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 12-02-2001, 02:18 PM
Administrator
Jack Olsen's Avatar
If memory serves, US height was 26.5 front 26 rear (measuirng from high point of fender arch to ground. "Euro" height is 25.5 front 25 rear. The Euro height looks better. You can go as much as an inch lower, usually, before you've got to start worrying about contact. Early cars should have a slight 'downward rake' look to them.
If memory serves, this was the car at US height:
Old 12-02-2001, 03:10 PM
CamB's Avatar
Oh, for the record, my car does have the downwards rake (front fender to ground 1/2" HIGHER than rear) - I took the photo above while the car was parked on a fairly steep hill with the handbrake on, and I had to tilt the camera to make it flat. This makes car look a little high in the front.
1975 911S (in bits)
Old 12-02-2001, 04:13 PM
Stay away from my Member
campbellcj's Avatar
My car is very low...24.25" front, 23.75" rear.
I am pretty careful with it over speed-bumps, dips and driveways so I have never had a problem at all.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 12-02-2001, 04:36 PM
not_sure's Avatar
Mine sits at about 25", it just looks so high for some reason.
Tom
71T
Old 12-02-2001, 06:43 PM
Administrator
Jack Olsen's Avatar
15-inch wheels make the car look a little higher, only because there's more space between the rim and the fender.
Old 12-02-2001, 07:44 PM
JAE JAE is offline
JAE's Avatar
Yours should be at least in the ball park Tom. My SC is 27 in the front and 26 in the back. I can fit my hand sideways above the tire in the front! That's with 16x7 wheels and 205x55's in the front. The rear is much better with 8's and 225x50's. Generally, the Look is really bad though.
I'm getting it lowered in a couple of weeks and just assumed that I would go with 25.5 front 25 rear. Any SC owners who are pleased with their height tire combo- I would appreciate the info.
Thanks,
Joe
'80 SC Targa
Old 12-02-2001, 09:06 PM
expat's Avatar
lowering
1987 Carrera with stock 6" & 7"
front 24.25, rear 24.5 - no tyre scrubbing at full tilt driving, but need to watch for steep inclines/declines in some carparks. Have a skid pad on the front and a tow hook that protects the underside front cooler.
Cheers
Mark
Old 12-03-2001, 07:36 AM
24.25 (front) 23.75 (rear) The lowered look is a nice look But watch out for those driveways and large speed bumps..Those can hurt sometimes..
84 EuroCab
Old 12-03-2001, 11:07 AM
not_sure's Avatar
Smile
Thanks for the input, I guess as soon as I get my brakes back together I will look into the ride height. I really want to get some 16 inch wheels, but then again there is a certain SC thats calling my name....
Tom
71T
Old 12-03-2001, 07:30 PM
