Early 911 Question - When points go bad
Can someone with some experience with points in the early cars tell me what symptoms a bad set of points displays? I checked the gap and cleaned the contacts (a little black) but I don't have a dwell meter. Any info would be appreciated.
1972 911T/S MFI Survivor
Old 01-23-2011, 03:08 PM
Do you still have the CDI ignition in your car? If so, the tach typically starts to act irradically when the points need attention.
However, with the CDI, the points are only a signal to trigger the CDI. Getting the gap and dwell correct is not that critical. Setting them close is good enough.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 01-23-2011, 04:22 PM
Poor performance and missing are usual sxs. As the point gap and hence dwell angle changes so does the timing. The rubbing block tends to wear closing the gap. Points can arc forming little blobs of metal and even bridge the gap. When this happens to coil doesn't get a clean signal. If you have significant arcing you should replace the condensor. This site is for Yamaha motorcycles but the principles are the same.
IGNITION BREAKER POINTS MAINTENANCE
Old 01-23-2011, 04:34 PM
HarryD's Avatar
What problem are you having?
With my car, at every oil change I burnish the points with an ignition file, wipe the inside of the cap and verify that each spark plug wire is properly seated.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-23-2011, 05:20 PM
I got tired of points and put a Pertronix Hall effect module in my distributor. I don't think about points any more. Best $100 i have ever spent.
Dwell meter is a great idea. Dwell does have an effect on you timing.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 01-23-2011, 05:38 PM
haycait911's Avatar
Pertronix!!!
Old 01-23-2011, 06:19 PM
Banned but not out, yet..
RSBob's Avatar
I will say it one more time for emphasis Pertronix! Get it and forget it.
Old 01-23-2011, 06:29 PM
Pertronix! But keep your Points in the glove box just in case the Pertronix fails.
Old 01-23-2011, 07:03 PM
Thank you everyone.
The problem I am having is lack of performance, a little bucking while accelerating, and a sense that the timing is off. The car becomes harder to drive smoothly and seems to run a little hotter.
The last time this occurred a mechanic burnished the contacts and reset the gap, so I suspect the points are going bad again.
I considered the pertronix but I don't have the experience to remove the entire distributor and get it back correctly. Plus, since the car is completely stock (to the eye) I wasn't sure I wanted to add an extra wire to the fuse block.
I have changed points, but it has been 25+ years. I think I'll give it a shot and see what happens.
Old 01-24-2011, 09:56 AM
Changing points is not a big deal. Just make sure you have a dwell meter and a good timing light.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 01-24-2011, 10:04 AM
cycling has-been
bkreigsr's Avatar
improperly gapped points usually show as a bouncing tach and erratic idle, and, as pointed out, if they are to the point where the are almost closed, the symptoms become very similiar to what you are describing.
if it's been 25 years, be careful with the set screw when you get it out, if you drop it, it's going to go where the sun don't shine, and you better have a replacement handy - you'll see what I mean when you get in there.
when's the last time you inspected the mesh filter inside the gas tank?
- just pull out the gauge sending unit and shine a flashlight in there. Bill K
Old 01-24-2011, 10:05 AM
OMG - what a difference. I installed the new points I got from our host, gapped them at 014 and all the problems disappeared. No backfiring, no stumbling, runs cool and strong.
Upon close examination of the old points, I noticed not pitting, but the plastic/bakealite "cam follower" was very worn. With strong reading glasses on I could not see them open - but I suppose they must have since it did run.
Also, my very erratic tach problem went away. Glory be.
Old 01-30-2011, 08:27 AM
Follow up questions:
- Anyone know the expected life time of a good set of points?
- I had to remove the flapper mechanism on the air cleaner to get to the screw that holds the
points. Is it possible to do the job without removing this mechanism?
- Is there anything wrong with just leaving that mechanism off?
Old 01-30-2011, 08:29 AM
David, I replace the points every 10-15k or every three years (garage queen). I would order the Bosch Distributor grease from our host and apply that to the shaft where the "cam follower" is hitting. You should get a dwell meter off of e bay and take the guess work out of the point gap. I am assuming that you are checking the timing to make sure it is correct. If not, get Wayne's book and a timing light from a local automotive parts store or e bay. Good luck. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 01-30-2011, 09:00 AM
+1 pm the Bosch dizzy grease. Don't use any other grease. Without a SMALL dap of dizzy grease the point block will wear very fast causing your gap to decrease.
Old 01-30-2011, 05:32 PM
Is there something special about distributor grease? I used the smallest amount of white (lithium?) brake grease but I can redo it if necessary.
Old 01-31-2011, 10:33 AM
HarryD's Avatar
Lithium grease tends to break down in the ditributor to make a mess due to the ozone formed from the sparking on the high tension side.
Distributor grease is specifically designed to resist this attack.
A tube of the stuff will last lifetime.
Harry
2020 MB E350 4Matic
Old 01-31-2011, 11:19 AM
points need to "break in"
if no grease applied it could be a few hundred miles
if greased it could be a 1,000 miles
if me i'd check timing every couple of hundred to know what's happening with point gap. When all is steady then every 5k miles
this is only my routine with points
and Bosch points is quality imo
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-31-2011, 12:12 PM
Besides Pertronix, Crane Cams as well as other manufacturers offer a breakerless replacement for the Bosch distributor.
Sherwood
Old 01-31-2011, 04:44 PM
If you have the skill to successfully replace the points you can install a Pertronix. Same level of (non-) difficulty. That being said, maintaining the points works just as well.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 02-01-2011, 06:05 AM
