I guess I'm an idiot
My oil pressure warning light isn't working.........I really don't know why.
I tested and there is power to BOTH leads! Is that right??
Dan '86 911 Targa Driver '76 911 Targa 3.0 Track Toy 46mm PMOs, 10.5/1 J&E,Web Cams, Wide Body fenders, 23mm and 30mm Hollow T-Bars, 930 Sway bars, Bilstein Sport Shocks, Plastic Bushings (too damn squeeky) |
Not certain but I believe the sensor is a grounding point, shouldn't have any current.
Are you sure your checking it right? I've been known to have the voltmeter on ohms instead of volts. lol
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
That's funny! I actually went back out to the garage to check the meter!
No, I am checking for current at the wire ends that attach to the light bulb in the gauge. Both have current, when I take the bulb out and put current to one terminal and ground the other the bulb lights up.
I recently built a 3.2 that got a new idiot light switch and it does stay on on start up until it trips at 1500 to 2000rpm.
I had a few last year or two that leaked until I just threw all away, theyre a pain to change once the engine is in the car especially on a 3.0. Bruce |
Sounds like we have a wire crossed or shorted. Just my .02
What are the colors of the two separate wires connected to the light?
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Senior Advisor
With the engine off and the ignition on the light should be on meaning it a complete circuit. so you could see power at both ends (current flow). Better to check if the switch works. Attach a meter to both posts on the switch, with the engine not running, it should read 0 ohms, when you start the engine it should read infinity. Then you know that the switch works. now check the wires from ground to the light in the dash to power.
08 Cayenne Turbo |
I would say that 12 volts on both sides of the bulb contacts makes for non-glowing bulb, no? Current is measured in series. Hooking up VOMs to voltage potentials, while positioned on the OHMs scale will eventually take it's toll on the meter,...ALWAYS verify your scale selections BEFORE making the connections.. Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
[QUOTE=dshepp806;5280063]+1.
"I would say that 12 volts on both sides of the bulb contacts makes for non-glowing bulb, no? " Correct, that is exactly the case. My question is how does the light go on when the key is turned? Does that ground one of the sides or is something else screwed up? Anybody else have their speedo out so you can check for current at the oil pressure light?
Gary H 1978 911 SC
No you are not. An idiot would not worry about fixing it.
To your question, yes, the switch provides a ground path to complete the circuit.
Does your light in fact turn on when the key is turned? (but without starting the engine?). If so, it sounds like your circuit is working - since as James Brown pointed out, the switch is closed (meaning no oil pressure). On engine start, pressure should be ok, switch opens, (no current) light -> OFF (and you can still have +12V at either side of the bulb). Unless you're saying you have a known oil pressure issue and no light.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
dont think in terms of current. the only way, well not really the only way, to measure current is to put an amp meter in series with the circuit. the other way is to measure a voltage drop across a known resistance then its E/R=I.
you want to look for voltage. the reason you see or measure votlage on both sides of the light is becuase the one side is not grounded. voltage looks for the least resistance to ground, if say the P switch is bad, or open, then the meter becomes the path to ground and it measures the full 12v. if the P switch were good and closed and providing a path to ground, the meter would read 0v. most people like to say you have something shorted, but in this case you have an open. it may be the P switch is not closing or a broken wire or a ground wire came off. when something is shorted, you are generally blowing fuses or you will have a constant drain on the battery, depending on if the short is before or after the load, IE- light bulb, radio, etc. if you have a test light, it is easier to use
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
