"farking Porsche hero"
Rich Lambert's Avatar
Front Torsion Bar Position
I forgot to check when I pulled the bars out...do the ends marked L & R go to the front or the rear. I'm assuming it matters...
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 04-04-2010, 12:16 PM
I'm here to cause trouble
jimbauman's Avatar
Towards the rear.....
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 04-04-2010, 12:30 PM
Southern Class & Sass
Dixie's Avatar
For the front, It only matters that the left and right are on the correct side. Not what end is in front. The torsional twist is the same regardless of what end is in front.
If you don't believe me, try this little experiment. take a ruler or stick. Hold it by each end. Point it way from you to make it easier to visualize it as the front torsion bar. Apply a twisting force to it. Front end down, back end up. Now, without releasing any tension, rotate the ruler so the back end is now in front. Notice the force applied remains the same. Front end down, back end up.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 04-04-2010, 12:44 PM
Thanks guys!
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 04-04-2010, 04:48 PM
