1977 911 transmission with a 3.2 engine
Apologies if this a stupid question : Is there any reason not to mate a 3.2 engine to the original transmission in the 1977 911S ? The transmission has been re built.
911 Coupe |
I would rather be driving
Just make sure you have the 915 flywheel and not the G50 (87-89). Otherwise, just cut the notch for the flywheel and reference sensor to read in the top of the bell housing.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
AutoBahned
how low will 1st be? the 1975 tranny has an R&P that works well with the torque of a 3.2L - IIRC, the '77 does too
good time to put a stornger side cover on also |
Just notch it and run it...It will require a 915 clutch and flywheel as mentioned and ring gear
Bruce |
'77 used 915/60 or /61trans w/ 8:31, gearing will be fine for a 3.2, it will be somewhat more sporting than any of the '84-89 transmissions, but not crazy.
