<insert witty title here>
Christien's Avatar
One more oil leak solved! (I think...)
I've had oil dripping on heat exchangers for some time now - really annoying and stinky, especially sitting at a traffic light. Remember Pig Pen from peanuts? That's what I felt like
Well, one cheap little bugger of a seal, and I think it's solved! I say think because there's still some residual oil on the heat exchangers that has to be burned off, and I haven't had a chance to have a really good, hot rip in the car since replacing the seal on Monday.
If you have a similar problem (most noticeable on deceleration because of the weight transfer to the front, which is where it leaks from) then I couldn't recommend this enough - it literally took less than 15 minutes - 2 10mm nuts and a small screwdriver to pry the cap off (careful, it's soft). No mess, no spills. Here's the original thread I posted about finding the right seal. Might only apply to 1972.
Oil filter housing leak - specific to 1972
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 04-07-2010, 07:00 AM
