H4 Mounting Screw
I've boogered up the heads on the mounting screws and will need to drill them out, but I can't find the direct replacement screws. I need 2 chrome lens head screws, H4 to headlight bucket. From our host I bought 911.631.114.01 (5X18) but they are black and the head looks smaller than what came with the H4 when I bought it. Any source for the original chrome mounting screws as supplied with the H4? Thanks
'56, '59 356A Coupes '67, '68 912 Coupes all gone '72 911T coupe |
abides.
These guys?
911-631-132-00-M260 (for trim ring) 911-631-033-00-M260 (for H4 headlamp)
Graham 1984 Carrera Targa |
To be honest, I'm not sure. It's been awhile since I installed them. I don't think I had the two-screw set up, just a chrome phillips head screw. I may have to drill them out to determine what these screws look like, I just would rather have replacements on hand before destroying the old ones.
abides.
Those sound like the screws that come with sugar scoops. The slotted screw above is stainless and should work a lot better with your housings.
Thanks,
Just drilled out a screw and it looks just like this one, but has a shoulder underneath the head and is about 5mm longer and is chrome. This one is what I ordered, and while black, shorter, and without the shoulder, works fine: 911.631.146.01 M100 (Pelican Number)
I've one of these to drill out....the head snapped off!
I do have the proper replacement screw...... Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
