sbedard's Avatar
starting point for co adjustment
I hate for my first post to show my ignorance. Is ther a sarting point for co adj. 78 911 SC.I was having high idle issues and tried to adjust co and have now lost where I was and car will not start
Old 04-11-2010, 01:22 PM
grateful user
don gilbert's Avatar
Youve prob. flooded it to hell buy now. Watch out for hydro lock. If severly flooded, pull plugs, disc. fuel pump and coil wire, crank it clear. Ive done this too before (lost original reference) by diss. sensor plate assy. Put it in the. middle, you can manipulate the sensor plate by hand till you get it close enough to idle.If you are exper. enough you can tell with your nose, idle, and just cracking the throttle body to get it close, But if you don't feel you are knowledgeable enough to do this, to be safe for high rpm afr's, on a non 02 car, you can rent a gas analyzer from you local parts store, and set it to spec. 3.5 on a non 02 car i think, specs are in the Bentley. Aparently it did not fix high idle prob, ( it usually dosent, as there are numerous other things that cause high idle) Start looking for vaccuume leaks, bad cis components once you get it to start. Just remember, everything you adj, effects how other things work to. Fix vacuume leak, idle is to low and must be adjusted. I saw a guy adj. his idle once by moving his dist. around. Talk about under informed.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 04-11-2010, 02:10 PM
sbedard's Avatar
Thanks Don,
I'll give that a shot and yes she is a tad bit flooded!
Old 04-11-2010, 03:16 PM
