Helios59's Avatar
Care To Diagnose These Glitches?
My beautiful '86 usually runs great, but every once in awhile, she throws me an unpleasant curve..maybe that's why I call her my "second wife."
I've had three incidents in the past two months. Twice she died while driving, moments after I started her from cold. Both times she started right up again.
Starting from cold, I regularly need to goose the gas to get her running. She'll then catch and run fine. She idles very regularly, even sitting in traffic, and hot starts are not a problem.
Today, after an uneventful ride to work, I parked her in an enclosed underground garage. Three hours later, I attempted to start her, and it took four tries to get her to catch. After that, she drove home without a hitch.
Fuel delivery problem? Open loop problem? The DME relay is 10 years old...I'll switch it out this weekend. Could it be starting to go?
Whatever the diagnosis, I'm planning to replace the fuel pump, as it's 12 years and 42K miles old and I just figure a new unit would be prudent.
Any other guesses? Thanks![
Ray
1986 Turbo-Look Cab
White Gold/Burgundy
Old 04-08-2010, 06:11 PM
grateful user
don gilbert's Avatar
possible temp sensor, or dme going bad.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 04-08-2010, 06:16 PM
Member 911 Anonymous
DRACO A5OG's Avatar
DME Relay.
No need to replace fuel pump. "if it aint broken don't fix it"
If you want to make certain of the pump, test it first via Bentley Guide.
Hose, clamps and cheap air guage can determine if it is failing.
'85 Carrera Targa
PCA/POC
Old 04-08-2010, 09:57 PM
