trans-differential
Please help, how to find,or test transmission to determine if the differental is limited or non limited 1976 911 S , Thanks for any help
Its very easy,...
![]() With the transmission in neutral, the rear wheels rotate the same direction when turned by hand if you have an LSD. With an open differential, they will rotate opposite directions.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
trans, diff
Thanks Steve, in neutral one tire turns at a time , in 1 st. gear tires rotate in opposite direction, I guess this would be an open diff? Any feedback please, Thanks,Norm
jack up one side, if you can turn the wheel, it is open
Max Sluiter
Open diff.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
