SC Sunroof Questions-Part Deux
So I've resolved all the mechanical stuff, but need to deal with the actual sunroof headliner. In the first picture, you can see why I had to attack this. This was the way it looked when it came out.
The other questions are the individual pieces. The big one that you wouldn't see has a cut in it almost all the way across- except on both ends. Is this the way it's supposed to be? Can anyone tell me or point me to a diagram as to where all of thes pieces go. Some I've been able to figure out because of holes for the clips. Does anyone sell this upholstery separately from the whole headliner? I'd prefer to reuse what I have though, because of match and cost. Thanks in advance. ![]() ![]() ![]() ![]()
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
I am tackling the same issue myself. I have my sunroof out of my Carrera and I am replacing the headliner only for the sunroof. Mine is black and perforated. I was able to locate just that part from PartsHeaven for around $40. I tried Pelican and the dealership and was unable to find that part only. As soon as I get it and take it apart, I can get some pictures.
I figured out that the big piece of vinyl is supposed to be split. A flap from the headliner goes through it. (It is the exact width of the split.)
