-   -   Wiring a flasher relay....need help (http://forums.pelicanparts.com/porsche-911-technical-forum/536285-wiring-flasher-relay-need-help.html)
Joe Bob 04-11-2010 05:53 PM
So, somehow I toasted a 2 prong flasher for the turn signals.....it's an FL 32. The wiring has been changed under the tank, both spade connectors are the same size.
Does it matter which connector goes to which male prong? The box has no directions, the male spade connectors are labeled, "X and "L". I plan on putting a 25 amp inline fuse on each side......
Any REAL help is appreciated.
HunterVonWurst 04-11-2010 05:58 PM
I would try it either way. I don't think you're going to hurt anything if you hook it up wrong.
tyro 04-11-2010 07:05 PM
X: +12VDC
L: Load
Some info here:
Tridon
Joe Bob 04-11-2010 07:10 PM
Thanks...so turn the key on, one lead should power up and light the test lamp or show 12v to the Fluke, that goes to "X" and the other to "L"?
Joe Bob 04-11-2010 07:17 PM
http://www.tridon.com.au/Products/img/z-SD12%20cir.jpg
