RETIRED
Joe Bob's Avatar
Wiring a flasher relay....need help
So, somehow I toasted a 2 prong flasher for the turn signals.....it's an FL 32. The wiring has been changed under the tank, both spade connectors are the same size.
Does it matter which connector goes to which male prong? The box has no directions, the male spade connectors are labeled, "X and "L". I plan on putting a 25 amp inline fuse on each side......
Any REAL help is appreciated.
2012 ML350 3.0 Turbo Diesel
Old 04-11-2010, 06:53 PM
HunterVonWurst's Avatar
I would try it either way. I don't think you're going to hurt anything if you hook it up wrong.
Old 04-11-2010, 06:58 PM
tyro's Avatar
X: +12VDC
L: Load
Some info here:
Tridon
Jess
1980 911SC Euro
1993 Audi CSQ
Old 04-11-2010, 08:05 PM
RETIRED
Joe Bob's Avatar
Thanks...so turn the key on, one lead should power up and light the test lamp or show 12v to the Fluke, that goes to "X" and the other to "L"?
Old 04-11-2010, 08:10 PM
RETIRED
Joe Bob's Avatar
Old 04-11-2010, 08:17 PM
