clutch pedal removal
Any good ideas on how to remove the clutch pedal off the shaft after removing the roll pin when rebuilding the pedal cluster. The pin came out fairly easy with a punch and some PB blaster. So far the clutch pedal isn't budging off the shaft. Thanks Jerry
some penetrant, a well adjusted vice grip, hammer and a large drift?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Mine moved freely after the pin was removed...
- '72 911T - '81 911SC Euro |
