Send a message via Yahoo to tmctguer
installing my robotek this saturday
i'm going to be installing a robotek unit in my '73 911E this saturday. i realigned my shift coupler several weeks ago to cure a 2nd - 3rd shifting problem i was having. at that time, i also replaced the shift coupler bushings.
this weekend, i'll be adding the robotek, replacing the plasting bushing at the bottom of the gear shift lever, and replacing the bushing that guides the shifter rod towards the shift coupler.
i'll let everyone know how much better (or worse, as the case may be) shifting becomes on my 915.
Old 12-06-2001, 02:10 PM
mm86911's Avatar
Keep us posted - I'm interested in the comparison to stock, short shift kit. . .
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 12-06-2001, 09:15 PM
Glasgow 911SC's Avatar
Any photos you could take and then post would be great if possible. I am interested in this kit aswell.
Old 12-07-2001, 05:46 AM
OK here's the report on my robotek installation.
for history's sake, i experienced a problem at the track shifting between 2nd and 3rd. a few weeks ago, i had replaced my shift coupler bushings and adjusted the coupler. that resolved that problem. however, i was looking to improve shifting even further, if possible. hence i purchased the robotek.
i would have taken photos of the installation process but my digital camera was not cooperating:
1). the installation was extremely easy. it took approx. 30 - 60 minutes in total.
2). while i had the shift mechanism apart, i went ahead and replaced the shifter ball socket and the shift rod bushing. that took 15 minutes of the time.
3). with needle nose pliers, 2 clips are removed that hold a 2 1/2" pin in place. this pin holds the shifter in place.
4). the existing pin is replaced by a robotek-supplied pin that is approx. 4" long. the old clips are replaced and the shifter mechanism now has approx. 1" of the new pin jutting out of the shifter housing.
5). the robotek shift unit (a small metal contraption with a long bolt, spring, and nut) is held against the shifter housing. after aligning the unit with the long pin, and marking 2 holes with a pencil, you drill 2 small holes in the shifter housing.
6). the robotek unit is then bolted in place and the shifter mechanism is then bolted back to the floor.
the results............
the 1st/2nd shift gate is now spring gated like 5th/reverse. it takes a few shifts to get used to. it definitely feels like accidental shifts to 2nd or 1st would only remotely be possible.
1st to 2nd shifting feels a bit "forced". and, when in 1st or 2nd, i get a definite noise that seems to be reverberating via the shift rod into the shifter housing. i'm not sure if this is a result of further adjustments that i need to make on the robotek unit or the shift coupling.
a major improvement is the shift from 2nd to 3rd. it almost feels like a knife cutting through butter. 3rd to 4th also feel very smooth.
so, tomorrow i plan to do another test drive. i will further analyze the unusual noise, too. it is possible that a shift coupling adjustment may eliminate the weird noise.
so jury's still out on the final verdict on whether it was worth $299. i'll probably know more after playing with it 1 more day.
stay tuned............
Old 12-07-2001, 09:59 PM
tobluforu's Avatar
Keep us posted. If that problem persists, give smartracing a call-they will help out. If all works out, you should submit a tech article on this.
Old 12-08-2001, 10:12 AM
drove around a bit more today. the noise i am hearing is definitely caused by the pressure on the shifter to be centered around the 3/4 gate while the tranny is engaged in 1st or 2nd gear. sorta like pushing the gearshift lever hard to the right while in gear.
i can almost eliminate the noise in 2nd by pushing the shift lever a little to the left. so there is some friction (in the tranny??) being caused by the spring mechanism as it relates to the shift rod.
the noise is definitely annoying and would not be pleasant to hear in city driving when going through the gears. i'm going to call the MFG on monday about the noise.
if the unit (or shift coupler) can't be adjusted to eliminate the noise, and it can be proven not be causing damage to my tranny, this may be something i put on my car prior to a track event. especially since it is so easy to install.
the only other downside to the unit is if you're not thinking, you can easily do a 1st to 4th shift, instead of a 1st to 2nd due to the tendency of the gearshift lever to move to the 3/4 gate.
more on monday after speaking with the MFG.
Old 12-08-2001, 11:18 AM
Senior Member
Doug Zielke's Avatar
Excellent report!
Now I can spend the $299+ on more models!
Old 12-08-2001, 05:00 PM
shifter
The Robotek is a nice looking unit. Hopefully it will fulfill all your desires.
A friend took a small brake spring and hooked it under the base of the shifter, came up to the top of the shell and hooked the other end to a piece of metal attached to front the shell and now the factory short shift always returns to the 3rd gear gate. Only $0.39. Works great too.
___________________
Steve- 62 356 S90 Sunroof-sold 11/16
73 911 No longer Targa-3.2L Running GT4
88 Carrera G50 sold 2019
2015 Cayman GTS
Old 12-09-2001, 11:02 PM
rob911's Avatar
I was thinking about a "home-made" robotek.
Is it really as easy as I imagine?
You say your friend did this, will you be trying it?
Rob '84 3.2 cab - random gearbox
01 Maserati 3200 GT Assetto Corsa
84 3.2 cabrio - gleaming
99 Alfa Romeo 166 3.0 V6 super - still going
03 Fiat Punto 1.2
http://www.pelicanparts.com/gallery/rob911
Old 12-10-2001, 03:00 AM
915 tranny and shifting
Guys:
I was told by Steve Stomski, who makes the Stomski Couplers, that the following 3 to be changed and adjusted to get a true quick shift.
1. Factory Short Shift.
2. Stomski Coupler
3. Robotek
I have changed # 2, it is definitely better than the stock coupler, I will change #1 this week and will update.
Frost on the ground.........
Best regards,
Cecil Brando
68 912
86 911 cab
03 Element
Open Source rules......try ubuntu today!!!!
You are lucky if you get a hundred years in this life... use it wisely.
Old 12-10-2001, 06:19 AM
shift kits
Rob
Most definitely. Drove his car and it was great. Would like to afford the real one, but this is the way to go for me.
The coupler is nice too. Smart Racing's is the way I will go. Have seen both.
___________________
2015 Cayman GTS
Old 12-10-2001, 08:45 AM
[b]"A friend took a small brake spring and hooked it under the base of the shifter, came up to the top of the shell and hooked the other end to a piece of metal attached to front the shell and now the factory short shift always returns to the 3rd gear gate. Only $0.39. Works great too."]/b]
I've got a mental picture of this modif., but you and your friend will receive the gratitude of 100's if you could post a pic or two of his shifter.
Regards,
Sherwood Lee
http://members.rennlist.org/911pcars
Old 12-10-2001, 09:31 AM
shifter
Will see if I can get a picture and post it.
___________________
2015 Cayman GTS
Old 12-10-2001, 09:38 AM
rob911's Avatar
Originally posted by 911pcars
[B]"A friend took a small brake spring and hooked it under the base of the shifter, came up to the top of the shell and hooked the other end to a piece of metal attached to front the shell and now the factory short shift always returns to the 3rd gear gate. Only $0.39. Works great too."]/b]
Regards,
Sherwood Lee
Moi aussi,
any more detail would be fantastic. Thanks for the tip
03 Fiat Punto 1.2
Old 12-10-2001, 09:51 AM
i called robotek this morning, and they believe the noise is due to a mis-adjusted shift coupler. they advised me to make a slight change to it and see if the strange noise goes away. as usual, they reported that no one had ever had this problem in the past with the unit.
i will do that this weekend and see what happens.
Old 12-10-2001, 03:40 PM
Senior Member
ohecht's Avatar
Any developments here, either with the elimination of the vibrations with the Robotek or with finding diagrams and a part(s) list for the cheap version?
Olivier Hecht
1982 911SC
Old 12-15-2001, 07:10 AM
shifter
I have been promised a picture that I can post. Still waiting for it to come.
___________________
2015 Cayman GTS
Old 12-15-2001, 07:24 AM
i have been diverted from my robotek adjustment to my oil cooler installation. haven't forgotten........still rumbles.....will adjust in the next few days and report back.
Old 12-15-2001, 05:27 PM
APKhaos's Avatar
Steve,
I'm promoting this back up the post list to remind you that we are all hanging out for your pics of the $3 robotec equivalent. If this really works you will have hundreds of 915 owners owing you...bigtime.
I'm up for trying the mod - just waiting for pics, and any trick setup clues your friend might have. Thanx
Tony K
'89 944T
944 SuperCup Champ 2004 & 2005
'85 Carrera - Sold [sob]
TrackVision
944Cup
The 999 Site
Old 12-16-2001, 08:12 AM
shifter
Folks
My friend has not been able to get a picture to me, but he did post the following on 12/17.
This post is in regards to the Robotek theads "my friend installed a spring in his shifter holding it against the 3/4 gate for .39 cents. I installed this set up in our '73 targa about 5 years ago. We've been tracking the car for the past 2 years with no problems. I showed this trick to some friends, one of which posted a thread to the Robotek installation. Below is a description of how I did it. Hope it makes sense. I've done this modification with the shifter in the car as well as out.
1. Looking down on the shifter, remove the top nut holding the shift assembly together.
2. Install a small plate approx. 3/4"w x 11/2"l x 1/16" thick. I used a pre-drilled steel strap that is used to hold down the back of a cassette/cd player to the car chassis. It's thin & strong. The right end of the plate goes over the stud and is secured with the top nut (leave loose). The plate should just cut across the left corner of the factory top steel plate.
3. Drill a small hole thru the plate where it cuts across the corner.
4. I used a rear emergency drum spring, that holds the back of the 2 shoes together. It has 2 long legs and the spring is in the middle. Used full length it has slight tension holding the shifter against the 3/4 gate. I cut off about 1/4 of one of the long legs and formed a new hook.
5. Hook the long leg to the bottom of the fork (the retangular piece that holds the gear shift lever in place. Looking down from the top of the housing the spring should be on the outside of the fork resting against the top left side. Pull the spring up and clip it into the hole of the top plate.
6. Move the top plate so the spring is against the housing and tighten the nut.
The length of the spring determines the tension. You may want to make a couple at different lengths until you get the tension you like. The spring does not interfere with the shifter going into 1st. I've used this with the stock throw, Weltmeister short shift, and currently with the factory short shift. In my current set up the spring is taught enough to pull the shifter to the 3/4 gate with no effort from me. Same coming from 5th to 4th.
___________________
2015 Cayman GTS
Old 12-18-2001, 07:13 AM
