72 oil filter housing leaking
I have a small leak on what seems to be the back side of the oil filter housing located on the right hand side of the engine compartment. Is there a cover that comes off back there (can't see it) if so is there a gasket or something that can be installed to stop this leaking?
72 911 Although it is done at the moment, it will never be finished. |
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Thanks Jeff,
No front cooler on the bastard. So what you are saying is that it's an O-ring that needs to be replaced, if so should I buy the one for the thermostat? Thanks again
<insert witty title here>
I just did this, and it's the easiest job I've ever done on the car:
One more oil leak solved! (I think...)
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Awesome, so it looks like number 14 on the diagram, can this be done without taking the housing off, with mirrors, etc??
Yes and no
Yes, it can be done without removing the housing, and no, you don't need mirrors. It's a piece of cake - 2 10mm nuts that are easy to access, grand total 30 seconds. Then the only tricky part is prying off the piece. You have to be careful because it's aluminum - get the smallest flathead screwdriver you have. I tried using a razor blade, but snapped it, as it wasn't strong enough. Once it's loose, you just pull it out, cut the old o-ring off, clean it up with some brake cleaner, roll the new one on and reinstall. Grand total is less than 10 minutes.
Oh, and yes, it's # 14, part # 99970105350, superseded to 99970731440.
Great, one less leak to worry about.
