-   -   3.2 piston question (http://forums.pelicanparts.com/porsche-911-technical-forum/538078-3-2-piston-question.html)
Rodsrsr 04-21-2010 11:51 AM
3.2 piston question
I'm sure somewhere in this vast wealth of P-car knowledge someone will know the answer to this: Is it possible to mill down a set of stock 3.2 pistons (US version) "slightly" to lower compression? (for obvious reasons) I have heard of this being done on the 3.6 but I'm not sure if its ever been done on the 3.2
Thanks in advance!
sp_cs 04-21-2010 01:11 PM
My limited research prior to my engine rebuild suggests you can use a thicker base gasket to lower the CR to achieve the same thing?
Flat6pac 04-21-2010 01:15 PM
lower compression with the base gaskets. then you dont start with the balance puzzles
Bruce
Boostaddict 08-19-2010 01:28 PM
Hi
I also looking for a easy way to lower the compression on my Euro spec. engine and a thicker gasket seems to be god way.
is it somthing I can buy (or do I have to make on on my on) is there any problem with cam chains after that (the tensioner scouold take care of it) how much is needed to hit 8.5:1?
GrantG 08-19-2010 02:21 PM
I hope people are trying to lower compression in order to add forced induction and not because the fuel has become so crappy?
Boostaddict 08-19-2010 10:31 PM
of course turboscharge and loads of Hp :)
