Grappler
3.2 piston question
I'm sure somewhere in this vast wealth of P-car knowledge someone will know the answer to this: Is it possible to mill down a set of stock 3.2 pistons (US version) "slightly" to lower compression? (for obvious reasons) I have heard of this being done on the 3.6 but I'm not sure if its ever been done on the 3.2
Thanks in advance!
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
My limited research prior to my engine rebuild suggests you can use a thicker base gasket to lower the CR to achieve the same thing?
Shirish 1987 Carrera, Granite Green |
lower compression with the base gaskets. then you dont start with the balance puzzles
Bruce |
Hi
I also looking for a easy way to lower the compression on my Euro spec. engine and a thicker gasket seems to be god way. is it somthing I can buy (or do I have to make on on my on) is there any problem with cam chains after that (the tensioner scouold take care of it) how much is needed to hit 8.5:1?
Carrera 3,2 -86 |
I hope people are trying to lower compression in order to add forced induction and not because the fuel has become so crappy?
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods |
of course turboscharge and loads of Hp
Carrera 3,2 -86 Last edited by Boostaddict; 08-19-2010 at 09:38 PM.. |
