myamoto1's Avatar
How to remove parking brake cable - 930 Brakes
I searched and couldn't find anything that showed me how to remove the parking brake cable from the assembly on a 930 trailing arm. I have a Bently manual and don't see the "loosen this nut" that they show to pull the cable. Do I need to remove the shoes and everything to get access?
TIA
Josh
85 M491 Coupe - "Fat Bastard"
Old 06-14-2010, 08:40 AM
cycling has-been
bkreigsr's Avatar
If you can't see the cable-end assembly with the rotor removed, then yes, remove the shoes.
I don't think I had to remove them on my 73, or 77, but, either way, the rotor must come off.
Bill K
Old 06-14-2010, 08:54 AM
myamoto1's Avatar
Bill - thanks, the rotors are off and I was hoping to avoid taking off the shoes (that'd add one more while I'm in there project ), but it sounds like that might be my only option.
Josh
Old 06-14-2010, 10:15 AM
myamoto1's Avatar
Looking at the parts diagram, I don't see where the cable would attach (per what the Bentley says). I'm assuming the turbo set-up is different and the cable either hooks in at 36 or 37 in the diagram below.
Josh
Old 06-14-2010, 10:22 AM
1984-911 M491
Trog's Avatar
See page 8 in the following thread:
My Elephant Racing Suspension Upgrade
1984-911 TLC......SOLD
Old 06-14-2010, 11:22 AM
myamoto1's Avatar
Trog - exactly what I needed! Thank you!
Josh
Old 06-14-2010, 12:08 PM
