Crotchety Old Bastard
RarlyL8's Avatar
Post Need a Fastener Supplier
A few years ago a got a bag of studs from WURTH that fill the void left after removing air injectors from a 911 engine.
Well I need more now and they tell me that the part is no longer available. The nut is 10mm x 1mm pitch with a small head (large won't fit).
Any help is appreciated.
Old 06-25-2001, 11:04 AM
Friend of Warren
Post
How about studs with an allen head socket on it? My local hardware store sells those, although not sure if they have the size you describe.
Kurt V
72 911E
Old 06-25-2001, 11:09 AM
pwd72s's Avatar
Post
Try Metric Multi Standard, Dallas, Texas Ph: 1-800-527-5177 Good luck!
[This message has been edited by pwd72s (edited 06-25-2001).]
Old 06-25-2001, 11:25 AM
Post
Try SJS Products in Northern Calif. They specialize in fasteners 888-757-7500.
Old 06-25-2001, 12:12 PM
Post
1/8 pipe plugs with a square head work perfect. in most brass/steel fitting assortments at home depot or your local auto parts store. i use steel ones. they also come allen head style.
Old 06-25-2001, 12:41 PM
Thumbs up
Rarly try these links, if you need to have some made I can probably locate a job shop that could whip out a few on a cnc screw machine.
AMETRIC supply company 773-871-4450
2461 N Clybourn Ave Chicago Il 60614
http://www.buckeyefasteners.com
http://www.nutsandbolts.net/main.cfm
david 89 turbo cab
[This message has been edited by 5axis (edited 06-25-2001).]
Old 06-25-2001, 12:49 PM
RarlyL8's Avatar
Post
Thank you thank you thank you all!
I'll try those numbers and see what comes up. My local hardware store doesn't carry that size with a small head.
Old 06-25-2001, 02:58 PM
Early_S_Man's Avatar
http://www.metricmcc.com/
Warren Hall
1973 911S Targa
Old 06-25-2001, 03:09 PM
