Need info on Tap size
Anyone know what the tap size is for the air injector nozzle on the heads for the air pump lines. Or what size plug is it? Thanks
Old 04-23-2010, 12:57 PM
I forgot,it's a 76 2.7
Old 04-23-2010, 01:00 PM
Air injector tap size........
Supergas,
The air injector tap size for SC's is M14 x 1.5. I believe it would be the same for the 2.7 liter engine. HTH.
Tony
Old 04-23-2010, 02:51 PM
abit off center
cgarr's Avatar
10X1.00 will plug the hole. I see you need to tap them, I would get a thread chaser, a tap may leave the hole a bit loose.
______________________
Craig
G2Performance
Old 04-23-2010, 03:15 PM
All the treads are good,I was trying to figure out how to describe what I size I needed to plug.I saw 1 article someplace it was a torque converter drain plug bolt for a Mercedes. Hope someone can help me ID. Thanks Guys
Old 04-23-2010, 08:33 PM
Alii&Maui
Jesset100's Avatar
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 04-23-2010, 09:39 PM
Thanks for the info.
Old 04-24-2010, 04:32 AM
I ll go with the 10mmx1mm which is fine thread.
Bruce
Old 04-24-2010, 04:33 AM
