Side window seal removal?
Hi, can anyone tell me how you remove the rubber window to body seal on the rear side windows? I want to removeit, but don't want to damage it.
Adam
71 Bahia Red 2.2E (sold)
72 Silver 2.4 T (stock except for a 2.8 big bore kit)
69 Chartreuse 2.0E
Old 04-23-2010, 05:06 PM
Mark S
It's only a press in fit but a TIGHT one. Mix up some soap and water and with a small metal pick like say a nut pick lube a section and get it out of the channel once you get it started just use the soap/water mix and slowly pull it out. Depending on how old and weathered it is may come out whole may not. The tough part will be getting it back in.
Old 04-23-2010, 08:36 PM
Great thanks. I shall proceed carefully.
69 Chartreuse 2.0E
Old 04-23-2010, 09:45 PM
