kramer747's Avatar
rear deck lid
Installed new interior rear deck panel and the part closest to the glass at the back wants to push into the glass. How do you avoid this? It almost seems like it needs to be glued down or something
Old 04-20-2011, 11:40 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Detach the lid strut/s and remove latch pin and align lid as needed the reassemble the pin and strut.
Another trick would be is to remove grill and loosen condensor so you can reach in and tighten the nuts. It will allow you to align exactly where you want it.
'85 Carrera Targa
PCA/POC
Old 04-20-2011, 12:45 PM
kramer747's Avatar
I'm sorry -i didn't make myself clear -I'm talking about the upholstered interior deck lid that has the rear speakers in it.
Old 04-20-2011, 12:50 PM
mrk_d's Avatar
"Package Tray"
Mark
1987 Carrera Coupe
http://nvrmndclothing.com/
Old 04-20-2011, 12:52 PM
kramer747's Avatar
Just looked in the parts catalog and Pelican calls it a rear deck panel
Old 04-20-2011, 01:01 PM
DRACO A5OG's Avatar
Can you post a pic of you issue? Sometimes aftermarket speakers will interfere with the seating of the deck cover.
'85 Carrera Targa
PCA/POC
Old 04-20-2011, 01:02 PM
kramer747's Avatar
thanks I figured it out. The underlayment was warped and swelled up towards the glass and it was already crtacked so I pulled off a 4" strip. The deck panel sits a lot better. I put some dynamat strip to fill the void before I reinstalled deck panel
Old 04-20-2011, 07:25 PM
