Help with shifter bushing project.
Greetings,
I am in the process of replacing my shifter bushings. This are going OK, but I have one snag. In the picture below, I am having difficulty removing piece number 24 from the end of part 25. I did successfully remove the screw 26. Any trick to removing that piece? http://forums.pelicanparts.com/uploa...1272248553.jpg Thanks, Hank |
need to remove it to replace 22, 23, the nylon bushings, it should come off after backing out the bolt, might be tight from age, a few taps on a wrench (like the procedure to remove the shift knob) should do it.
I just did it and used a rubber mallet to get it off.
Thanks for the tips. I will be back at the shop tonight and see if it will free up.
Thanks, Hank |
| All times are GMT -8. The time now is 07:17 PM. |
