Hankford's Avatar
Help with shifter bushing project.
Greetings,
I am in the process of replacing my shifter bushings.
This are going OK, but I have one snag.
In the picture below, I am having difficulty removing piece number 24 from the end of part 25. I did successfully remove the screw 26.
Any trick to removing that piece?
Thanks,
Hank
Old 04-25-2010, 07:26 PM
Senior Advisor
James Brown's Avatar
need to remove it to replace 22, 23, the nylon bushings, it should come off after backing out the bolt, might be tight from age, a few taps on a wrench (like the procedure to remove the shift knob) should do it.
08 Cayenne Turbo
Old 04-25-2010, 07:40 PM
I just did it and used a rubber mallet to get it off.
Old 04-25-2010, 08:40 PM
Hankford's Avatar
Thanks for the tips. I will be back at the shop tonight and see if it will free up.
Thanks, Hank
Old 04-26-2010, 09:01 AM
Tags
shifter bushing
