Throw it on the ground!
Couple of brake line replacement questions.
Recently replaced G50 flex line and had trouble threading the fittings......meantime brake fluid continued to run out draining the reservoir. What a mess!
(1) Is it true that if you hold the brake pedal down it will keep the reservoir from draining while replacing the brake lines?
(2) If I had depressed the clutch pedal while replacing the G50 flex line to the slave, would that have prevented fluid drain?
(3) Finally, the SS brake lines are a different length (13-3/4" and 11"). Are the shorter lines for the front or the rear?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 04-24-2010, 04:53 AM
docrodg's Avatar
1. No, the brake cylinder cups will not have pressure against them in the MC and will leak still.
2. See #1.
Here is an easy trick: Disconnect the line and plug the end with a golf tee or similar item. On a fitting that it won't fit in just use a bolt that is the size of the fitting, if it still leaks a little put a small piece of bicycle innertube in the end of the blot to give it a little seal.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 04-24-2010, 05:30 AM
steely's Avatar
Mark,
I propped a 2x4 against the brake pedal approx 1/2way depressed. Blocked with another 2x4 on the seat front - got this info from other threads here, never gushed out/lost much - it was a big concern I had too before starting but I was pleasantly surprised. I did use a tray/litter box as backup, but hardly needed it.
Can't answer the slave cyl question.
Can't recall lengths, Wayne's 101 project book mentioned the ss lines end 'nuts' would be keyed differently (externl flat side) to differentiate front/rear, but the units I rcvd had NO keying for my 87. I just matched the lengths to the removed OEM lines.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 04-24-2010, 06:54 AM
Northern Motorhead
wildcat077's Avatar
Mark,
Yes the lines are different lenghts front and rear and you will also have to bleed your clutch slave cylinder which is on top of your transmission.
Requires a 7mm socket for the nipple,pain in the ass spot but once you figure out the best access position you'll be good to go.
I just did all that stuff on my car a few weeks ago.
Do as Dan says,with the 2x4's and you will have minimal leakage !
Cheers!
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-24-2010, 08:31 AM
Originally Posted by wildcat077 View Post
Mark,
Yes the lines are different lenghts front and rear.........
short up front?
thx
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-25-2010, 01:28 AM
According to Milt from another thread.....
"Long in front"
Hopefully not an April fools response as the thread was dated long before his Pelican Sabbatical.
Thanks Milt!
SS brake lines- short or long ??
Mark
1987 911 Coupe
Old 04-26-2010, 07:02 AM
thx
and nice 930 brake pics
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-26-2010, 09:42 AM
