-   -   Can I use CIS heads with carbs? (http://forums.pelicanparts.com/porsche-911-technical-forum/539333-can-i-use-cis-heads-carbs.html)
jbell959 05-04-2010 03:32 PM
I would tap and plug them... they should work nicely with your carbs
teachkenpo 05-04-2010 05:10 PM
Jbell, I appreciate the encouragement. I will get them tapped and plugged.
Once again, Pelican to the rescue. I can't imagine how I would have figured this out without everyone's help. Thank you.
John
Walt Fricke 05-04-2010 06:54 PM
There are many ways to plug these holes. I ended up with an engine with early MFI heads. The injector holes had been tapped, and allen bolts screwed in. Problem was that the bolt heads stuck up a bit too far for the PMO manifolds I purchased. Some quick work with a die grinder solved that.
But were I to use heads which needed a plug again, I'd try to use allen head set screws to get them out of the way. Or perhaps see if 1/8" aluminum or brass NPT plugs would work. Or find a lower profile bolt. Anything to keep all of the plug below the plane of the intake gasket.
