Can I use CIS heads with carbs?
Hi, I just purchased a set of newly rebuilt 73 CIS 2.4 heads. I was planning on using them on a 2.4 rebuild with Carbs. Is there anything significantly different with these heads that could cause a problem when using with the carbs? The build will be a 2.4e with 2.2e pistons and either solex or e cams.
Thanks,
John
1965 911 #301069 Light Ivory, 1965 911 #301983 Silver
1966 911 #302963 Polo Red, 1966 911 #302222 Irish Green
1967s, 1968 912 ,1969t, 1970s, 1970t, 1970 914-6, 1971e, 1972t, 1973.5t, 1976 914, 1987 911 Targa, 1991 Cabriolet
Old 04-27-2010, 06:14 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Shouldn't be an issue AFAIK.
Black Cars Matter
Old 04-27-2010, 06:34 AM
Thank you for the reply. Do you know if there are actually any differences to how a CIS head differs from a MFI or carb head?
Regards,
John
Old 04-27-2010, 03:05 PM
Senior Member
Superman's Avatar
I don't know. But.....I wouldn't expect them to be different. With carbs, I would use different pistons and different cams. But I doubt the heads would be any different. Unless of course you wish to twin-plug the heads.
Mocha 1978 911SC. "Coco"
Old 04-27-2010, 04:18 PM
rfuerst911sc's Avatar
I'm running carbs on two different 3.0's that were CIS originally with no problems.
Old 04-27-2010, 04:22 PM
There should be a cutout on the intake for the fuel injector. I believe you need adapters from PMO or the cutout can be welded and resurfaced.
Old 04-27-2010, 05:08 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
carbs on SC 3.0l, plug and play, direct simple swap. no issues.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 04-27-2010, 06:14 PM
AutoBahned
RWebb's Avatar
I guess people are assuming he will keep the CIS pistons also - if true, then sure he can run carbs.
IF he changes to different pistons, then I'm not sure.
Old 04-27-2010, 07:03 PM
Thank you again for all the replies. Just to clarify the various questions, here is what I am running.
2.4 crank
2.4 cylinders
2.2 pistons (to give it a little higher compression)
Solex or E cams
73 2.4 CIS heads
weber 40 carbs
I will run it and see how it goes. I will post results here.
Regards,
John
Old 04-27-2010, 09:48 PM
Max Sluiter
Flieger's Avatar
Regards,
John
CIS and carburetor heads are similar.
MFI heads have a hole in the intake port where the MFI injector sticks in. CIS injectors are above the head/port area and do not have this cutout.
Courtesy of Hans and Ed at KundenSport:
Old 04-28-2010, 12:09 AM
Regards,
John
Hi John,
No worries,......all you need are the proper manifolds that fit the CIS heads.
PMO makes them.
Don't forget to get an insulator kit, too.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-28-2010, 01:17 AM
pcar9119's Avatar
You can just port you old intakes also. I had mine port matched and they work great. The CIS heads will have the intake port notched out for the injector. I just put on new Gaskets and away I went. There is no need to weld up the head or buy 300.00 intakes from PMO.
Old 04-28-2010, 01:37 AM
E Sully's Avatar
The 73.5 CIS heads have the injector mount next to the port opening. I bought the PMO insulators notched for these. I had the local shop make aluminum plugs the same size as the injectors to plug the opening.
I ground the intake manifold to match the insulators.
Ed
1973.5 T
Old 04-28-2010, 08:31 AM
pcar9119's Avatar
Yeah, I was thinking 3.0 heads. They have the notch. Good luck with your carb conversion
Old 04-28-2010, 01:54 PM
Update with Pictures!
Ok, now I am really confused. Now that I have unpacked the heads, they look more like MFI than CIS. The heads are dated 1-73 and here is the picture.
I thought the CIS heads had the small groove in the intake. Was a 73.5 CIS different than other year CIS? How do I use these heads with carbs?
Thank You,
John
Old 05-03-2010, 04:04 PM
Those are CIS heads... the 73.5 engine was the only one with that type of heads. Starting in 74 the CIS injectors were in the intake runners. As Ed posted, you will need to plug those injector ports. Other than that they are the same as MFI or carb heads. The MFI heads have an injector port with threads... CIS is a press-in injector.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 05-03-2010, 04:15 PM
More update
From what I just learned, the 73.5 CIS did have a MFI looking hole in it for the injector. So, these heads are in fact 73.5 CIS and no one makes a plug for that specific half year application. It was suggested that I tap the hole and put in a plug. Unless someone has a better idea, I will give that a try. Seems like a shame to bugger up these heads by threading the injector holes. Perhaps I can just tap them partially so that they could be used in the future if someone needed original 73.5 CIS heads.
Thanks for listening to me think out loud.
Regards,
John
Old 05-03-2010, 04:21 PM
Thanks Jbell. Ed did state this, but I didn't understand it at the time. I do now. Thank you all for your patience with my rather slow learning curve on this topic.
Regards,
John
Old 05-03-2010, 04:23 PM
E Sully's Avatar
Here is a pic of my 73.5 CIS injector ports. I had the plugs made to fit the injector rubber grommets with a threaded end so that a bolt could be used to pull them out easier. Your heads seem to be missing the metal sleeve that would hold the rubber grommet.
Ed
1973.5 T
Old 05-04-2010, 07:18 AM
Ed,
That is part of what confused me when I saw your pictures the first time. Since these heads were rebuilt, those sleeves seem to have been removed. It was suggested that I just thread the head to take a threaded plug. Your plugs seem to be a press fit, but to do what you did, I would need to re-install those sleeves.
John
Old 05-04-2010, 08:30 AM
