Which is easier, front or rear suspension?
I replaced the rubber bushings on my front suspension on my 1985 Carrera earlier this year. I have been busy with other things but I am ready to attack the rear suspension. I plan to replace the shocks, torsion bars & of course the rubber suspension bushings with new Elephant racing bushings.
I have done a lot of reading but I figured I would throw out a couple of quick questions for the group. How much harder is doing the rear suspension than the front suspension? What do you suspect will be my biggest challenge? OK, one more question, what are the best how to threads ? I have found several but I always seem to miss the best ones.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Why are you replacing the torsion bars? Just wondering.
When I did the front end the t-bars had some rubbing, so I had to replace them. I went up one size and I want to match that in the rear. At the autocross it is more tail happy now. I can't really evaluate it too much since I still have the old shocks in the rear. I would never try a track day as it is now. Once I get the rear finished I will have a full corner balance & alignment done.
Senior Member
Read some more, particularly about what rear bars will best match your new front bars.
Interestingly, the stiffer end of your car will be the loosest. If you have stiffened the front, then this has made your car PUSH more (understeer). For autocross, you will want more oversteer. The softest part of your suspension is where the tires will grip the best. The stiffest end is where the looseness will occur.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
just finished rear, ready to start on front. I found 2 areas that were troublesome but not difficult.
1. The bolt that holds the swing arm to the torsion bar housing, can't access with engine/tranny in place, have to cut it in half with sawzall and replace. 2. Emergency brake pads, although not difficult, must replace springs in specific order and the pay very close attention to how the butterfly's that operate the pads come out. The axle nut is tight, i used 3/4 breaker bar with 3' cheater pipe to break free Pressing the new bearing in the swing arm can be done using long nut/bolt and washer to pull together, mine was fully seated but would not fit back into place, had to grind down the bushing to fit. Indexing torsion bars is easy enough, iPhone level app, the Bentley manual specifies degrees for various heights or search. Best of all, search "elephant racing" |
Checked out
The front set up is just a lot easier to work with, at every step of the way, with less things that tend to get "stuck" or frozen. For example, setting the ride height is a ton easier on the front, you can reindex the torsion bars in a minute or two without even taking the front wheels off the car, and you can adjust the ride height by just reaching under with a wrench, and not even jacking the car up. The rear is not so simple. |
Senior Member
![]() ![]() Yup, the rear is a bit of a PITA. Still, not that many parts. Do-able. Getting the control arm bolts out with the transmission in place depends on which way the bolts are facing. If you're lucky, they're facing inward and can be removed easily. Torsion bars sometimes don't want to come out at first, but with patience and finesse they will let go. Use the Wil Ferch Spring Plate Calculator. You will need to rough-set your suspension settings. Ride height first. Then camber. Then toe. Then drive it straight to an alignment shop where you will learn how far off you were. If you want to replace the bearings (not necessary if your bearings are fine), then any machine shop can easily do that for you. The control arm into which they are pressed will be off the car. And yes, the axle nut is on tight. I mean TIGHT. No less than a half-inch breaker bar will be needed, and you will need to slip a section of pipe over it for leverage. Put the knuckle of the breaker bar into the saddle of a jackstand. E-brake on. Car in gear. It will come loose with a BANG. When replacing that nut, if you fail to tighten it to the correct torque, it will be too loose and that will destroy the bearing. It's technically possible to get it too tight, but your chances of doing that are slim.
Glen, it's doable in a weekend. You'll need a thin wrench to adjust the ride height (check out McMaster Carr) for sure, and a large allen wrench that you can buy off the shelf from Sears to adjust the toe and camber eccentric bolts. You might want to have a torch and hacksaw handy to remove the old rubber, and a digital inclinometer. It's not hard. I'd leave the axle nuts alone. I can post pics of my rebuild last year if you can't find any good threads.
I had to get the external HD out anyway:
Measure radius arm inclination before and after removal and replacement: ![]() I think each spline is good for about 3 degrees or 3-4 inches or whatever, but if you re-index the outer against the inner splines, you get 1.5 degrees or so of inclination change. But don't quote me on the exact amount. Used longer bolts to press the cover on to the new rubber ![]() Done
When I removed mine with the tranny in, to install ER monoballs, they were the biggest problem I've ever faced in many years of 911 ownership-brake system upgrades, suspension rebuild and upgrades, an engine build and many other projects under my belt, so I think I speak from a bit of experience. Every car is going to be different in this regard, IMO. I got them off with some heat and a 4' long contraption of a wrench and 210lbs (maybe 225 back then ) of body weight, and 4 hours of my life.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
fronts are easier from the get-go. but once you take apart the rears, again and again,....and again..the rears just get plain easy.
poof! gone |
control arm removal
i removed both of my trailing arms today. the nut was outboard which meant i thought i was gonna drop the drivetrain. i removed the nut and tapped the bolt inward just enough to expose the head of the bolt and used my sawzall to cut the head off, then pulled out the bolt by the threads. thank god that worked, i could bear the thought of all the extra work. hope this helps......kevin
See that long fencepost...er breaker bar? Can you tell that I grew up on a farm? |
The main purpose of the project is to get the rubber bushings replaced and the shocks replaced.
I have a 3 foot breaker bar with the appropriate socket for the axel nut so that is covered. I did the rear wheel bearings two years ago. The CV joints were repacked back then. So that part is done. While I am in there I will rebuild the rear calipers since they are 25 years old and never touched. My biggest concern was getting the trailing arms off, and back on. I guess I will order a set of the trailing arm bolts and get them on hand. It is good to have the warning about the emergency brakes. I will take pictures and notes as I take it apart. The funny thing is when I mention rebuilding the suspension to non Pelicans they all think I am nuts. There were times when I was trying to get the front stabilizer bar back in place I would have agreed with them.
MBruns for President
They each have their own level of suck.
the front can be a pisser of the TB decide they are not coming out or you break off the wedge bolt (or ball joint removal) The rear can induce you into a swearing tirade if you can't get the tb cover to release or get your spring plate angle correct. Good times good times...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I'm here to cause trouble
I just replaced my rear spring plates with SAWs, and already had 30mm torsion bars. It was actually pretty simple. I can see where using stock bars and putting back the original spring plates would be a more involved job, with preload etc., and having to be super accurate with the spring plate angle. I didn't replace the trailing arm bushings - yet...
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) Last edited by jimbauman; 04-29-2010 at 11:15 AM.. |
They would. Part of this whole equation is also ride height and corner-balance.
Why are you taking off the control arms?
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Obviously I have not done a corner balance as yet. After I get the rears done I will have the full alignment & corner balance done.
As the car sits right now the front end is a little too low. It has just a garage alignment. The front shocks are new Bilstien HD and the entire rear is stock from 1985 with OEM Boges. The tires on it will get replaced once the alignment is done. I took it to our autocross just to see how it does. I have been autocrossing for 30 years and I did not push hard. I was not going to push hard enough to go off course. I can't wait to get the rear end done, I just dread the process of doing it.
