moneymanager's Avatar
Fix A Flat Used, cleanup question.
On road recently, woke up to find a flat rear tire. I carry no spare, just Fix A Flat and a tiny aftermarket pump. Jacked the car up a few inches, used both. 24 hours later, after a good deal of abuse, tire still holding air. So the stuff can work beautifully if like me you don't carry a spare.
Question: I'm told this stuff needs to be cleaned out fast as it will corrode the wheel. Anyone know what the best clean up method is?
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 04-30-2010, 07:47 AM
Have the tire demounted, then go at both it and the rim with soapy water. Oh, also have the flat repaire while doing that.
Old 04-30-2010, 07:59 AM
Simple enough! thanks,
jhtaylor
santa barbara
Old 04-30-2010, 08:07 AM
Recreational User
porschenut's Avatar
Where did you hear it would corrode the wheel? I haven't heard that.
Old 04-30-2010, 10:58 AM
muck-raker
kidrock's Avatar
I haven't heard that, either.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-30-2010, 11:02 AM
Harvey Weidman, a serious Porsche wheel guy, is alleged to have said this. He is also alleged to have said he prefers Slime which doesn't cause problems. Perhaps if he's listening he can straighten us out?
jhtaylor
santa barbara
Old 04-30-2010, 11:10 AM
rnln's Avatar
don't leave it in for too long. I experienced it. It eats aluminum wheel for lunch.
Fat butt 911, 1987
Old 04-30-2010, 12:46 PM
Northern Motorhead
wildcat077's Avatar
I've been using Slime in my ATV wheels since 1999 and haven't had a wheel disintegrate on me yet !
Although i would stand back when the tire tech ever attempts to remove the tire !
Messy is not the word ... lol
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-30-2010, 01:06 PM
I've not heard of the corrosion either, but I wouldn't doubt it. I can vouch for Slime, however. Used it on other allow wheels with no problems, and it is recommend as a preventative from flats--to be use inside the tire/wheel even without a puncture.
BTW, excellent comment about advising the tire tech if you've used these products. Remember, this is the guy you want to treat your Fuchs with special care!
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-30-2010, 06:55 PM
80-911SC's Avatar
never heard of it eating rims ............
now a question for the OP, why don't you carry a spare ?????????? i understand if its a weight thing, but still would disagree, and of you are at home then you would have the spare there, now if you just don't have one I would suggest you get one.
But to the first part, you should get the flat fixed, and clean the inside out, its just nasty, the best thing to equate the "current" fix is you now have chewing gum in your tire trying to hold the air in, its working know but for how long ???????????? It is a temporary fix to a problem ..........
americas tire will fix it for free, even if you didn't get it there if you need to save 5 bucks
Old 04-30-2010, 08:13 PM
