911freek's Avatar
Job description - logic relays 911.617.118.00 ?
Hello all,
I started hearing an annoying buzz from the dashboard, despite the doors being closed and the seat belt fastened.
After a minor investigation, it turned out that this relay is causing the noise.
Being a hot-blooded Italian I first took it out, and then Googled.
I understand this to be the US version of a logic relay that warns regarding seat belts and open doors. Franky, this I can live without, until I find a new one.
Question is if it does anything else (i.e. oil level warning or any other warning) that I should not be driving without?
Thanks,
My preferred concert venue? The driver's seat of an open-top 911.
Old 03-17-2011, 06:30 AM
On my car, 1974, the starter will not engage with this relay removed.
You can put a jumper in the relay socket with the relay removed to enable
the starter. The diagrams show only the items you have mentioned +
Emergency brake.
Many people run without this relay. If your car doesn't start without
it, see below (step 2) for jumper info.
Glen Pettigrew
Old 03-17-2011, 08:26 AM
911freek's Avatar
Many thanks.
The car starts, I believe this has been bypassed somehow before I got the car.
Old 03-17-2011, 09:52 AM
You don't mention the year of your car. US-spec 1974 cars of all makes were delivered with a start-permissive interlock.....the car would not start unless you were buckled-in. Often ran a parallel circuit to the seatbelt buzzer. I'm sure all by now have been deactivated....and this interlock wasn't done for Euro or ROW cars anyway.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-17-2011, 10:08 AM
