Whats the guidelines for getting a valve adjustment?
What are the general guides? Mileage? Time? Noise? Type of usage? My 89 hasn't had the valves adjusted for 5-6000 miles and maybe 3 years. I don't notice any problem, but am wondering if I should have them do it at the next inspection. It's not like I want to hand the garage $300 for nothing. When do you determine its time to adjust them?
You can do it yourself for less than half that, including oil and a filter. Now that the weather is good, you should do it now.
I believe 15000 miles is recommended to check clearance.
THe Bentley and Wayne's 101 books explain the procedure, if you do a search on the subject you'll find countless threads about it. Take care. |
If you're not running the car, there is nothing to change the adjustment. I do my valve adjustments every third oil change interval, every 9,000 miles.
Time factor is not specified in the Bentley, just mileage, 15K miles is recommended. Quote:
I was answering laundromatt's question. |
The guideline is every 15,000 miles, period. It's in your car's maintenance manual.
| All times are GMT -8. The time now is 11:17 AM. |
