Whats the guidelines for getting a valve adjustment?
What are the general guides? Mileage? Time? Noise? Type of usage? My 89 hasn't had the valves adjusted for 5-6000 miles and maybe 3 years. I don't notice any problem, but am wondering if I should have them do it at the next inspection. It's not like I want to hand the garage $300 for nothing. When do you determine its time to adjust them?
Old 05-01-2010, 08:04 PM
You can do it yourself for less than half that, including oil and a filter. Now that the weather is good, you should do it now.
Old 05-01-2010, 08:15 PM
I believe 15000 miles is recommended to check clearance.
Old 05-01-2010, 09:48 PM
Is there a guide for this somewhere?
1984 Carrera 3.2L Coupe, Guards Red
Old 05-02-2010, 12:08 AM
No sleep 'til... BROOKLYN
flatsixjunky's Avatar
from laundromatt
THe Bentley and Wayne's 101 books explain the procedure, if you do a search on the subject you'll find countless threads about it.
Take care.
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 05-02-2010, 02:21 AM
Being that I bought the car 11 years ago and put 30,000 miles on it, it would be a lengthy time between adjustments. If the car sits for lengths of time, is there a time factor? Thanks also for the DIY suggestion, but those days are long gone. As far as a guide, I meant when it should be considered, not how the procedure is done. I have helped doing them a few times but would rather have it done at the garage.
Old 05-02-2010, 05:54 AM
Tired Member
DaddyGlenn's Avatar
If you're not running the car, there is nothing to change the adjustment. I do my valve adjustments every third oil change interval, every 9,000 miles.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 05-02-2010, 06:27 AM
from 98911
Time factor is not specified in the Bentley, just mileage, 15K miles is recommended.
from 89911
I was answering laundromatt's question.
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 05-02-2010, 06:36 AM
Recreational User
porschenut's Avatar
The guideline is every 15,000 miles, period. It's in your car's maintenance manual.
Old 05-02-2010, 08:16 AM
