Weber soup
I know why FI was invented.
Old 05-04-2010, 03:30 PM
1966 - 912 - SOLD
lane912's Avatar
yes but they will be happy carbs after their bath. they will serve you well when cleaned properly
Old 05-04-2010, 03:38 PM
Dont know, good, bad or a combination of both?
Here is whats there:
venturi 27
main 105
air correct 170
idle 55
emulsion f1
Old 05-05-2010, 11:26 AM
There is a thin, teflon-like sheet wrapped around the end of each throttle shaft to reduce rotational friction. Not sure if the carb. cleaner (pretty aggressive) will have any negative affect on them. If so, the shafts will either be harder to rotate (material is distorted) or easier to rotate (material dissolved). Refer to an exploded view of components.
I would have removed the shafts.
Sherwood
Old 05-05-2010, 12:55 PM
1QuickS's Avatar
Be grateful to the teflon "bearings" as they preserve the throttle shafts from wear so they may be routinely salvaged during a remanufacturing process. The early Webers did not use this teflon bearing so they wore the bearings concurrently with the shafts. Check out further comments here: http://www.performanceoriented.com/technical.htm#ThrottleShaft
These carbs work very well when in good condition but after 30-40 years of various usage and maintenance have become a source of undue drive-ability issues.
Cheers,
Paul Abbott
www.PerformanceOriented.com
Old 05-10-2010, 08:43 PM
